What is this for around the output tube?
GERPUD
Post by GERPUD »
Hi
See picture.
Anybody have an idea of the purpose of theses components?
I can t find something similar anywhere....
Thanks!
Re: What is this for around the output tube?
Post by Stevem »
You need to post a better image, I can not enlarge it and keep it clear !
GERPUD
Post by GERPUD »
sluckey
Post by sluckey »
I've never seen that.
Zobel network, I think.
GERPUD
Post by GERPUD »
It take a fair amount of place on the pcb, it uses the biggest non polarized caps of the amp and i have no idea of its uses....
GERPUD
Post by GERPUD »
martin manning wrote:Zobel network, I think.
In a tube amp?
Why?
pdf64
Post by pdf64 »
My guess is that (being as it's SE), the network is feeding phase shifted B+ ripple to the cathode, in order for it to achieve a degree of ripple cancellation.
GERPUD
Post by GERPUD »
Ok, that would be a kind of negative feedback of the noise signal in the power supply that would be needed when using bad power supply design?
Since i have added a filtering stage with a choke, maybe this thing is not needed anymore...
pdf64
Post by pdf64 »
I can't see that it's part of a feedback loop; rather it's simply passively mixing some ripple into the signal path (at the power tube cathode), such that it will cancel itself out at the plate.
If you've amended the B+, eg such that there's a pi filter feeding the plate node, then (as it's passive) the network may be increasing the hum level!
GERPUD
Post by GERPUD »
I've tried deconnecting C24 and R35.
No difference on the noise.
No difference in the sound.
Looks like a very useless network...
Leo_Gnardo
Post by Leo_Gnardo »
pdf64 wrote:My guess is that (being as it's SE), the network is feeding phase shifted B+ ripple to the cathode, in order for it to achieve a degree of ripple cancellation.
Some engineer's clever solution for avoiding an expensive, heavy filter choke in the power surprise. Now you've improved the PS filtering with an extra cap & choke, the "bandaid" network has no use.
A cap 'n choke pre-filter does wonders for Champs and similar amps, IMHO well worth doing, good work GERPUD!
GERPUD
Post by GERPUD »
You're right.
It is a cheap amp, but it seems to not be a lazy cut and paste from other simple SE tube amps.
Indonesia seems to have hard working engineers...
matt h
Post by matt h »
(deleted)
