Laney VH100R bright cap
Emetal
Post by Emetal »
Hi guys, is the C10 on this photo a bright cap I need to remove in order to cut down on treble and fizziness ?
roberto
Re: Laney VH100R bright cap
Post by roberto »
Yes it is, no you don't need. :wink:
Emetal
Post by Emetal »
You do not think I should remove it? It's not on my amp it's on a friends amp who has it all stock original...
Gaz
Post by Gaz »
You can totally try it, and if it sounds too flat afterwards you can always try attenuating treble earlier in the pre.
John_P_WI
Post by John_P_WI »
Gaz wrote:You can totally try it, and if it sounds too flat afterwards you can always try attenuating treble earlier in the pre.
+1, or put C10 back, and increase the "fizz cap", C14.
Smokebreak
Post by Smokebreak »
And/or slap a 500p across R7
Emetal
Post by Emetal »
Ideas.. ideas.. OK :) will try all of them :lol:
roberto
Post by roberto »
Keep the circuit as is, and work on preamp voltages.
Emetal
Post by Emetal »
Slaped 500 pF over R7 but did not get rid of treble. Took out C10 and the got rid of significant amount of treble :-) Probably this will do it for my friend, but will look in to getting more bass and low mid, maybe will use the same trick I have in my amp: putting that little network of 2.2nF ll 22K between 4 Ohm tap and NFB..
