Source for speaker baffle ready to drop in?
bentonar18
Post by bentonar18 »
I am looking for a couple of sources for speaker baffles for a project for a customer. Baffles need to be cut out for a 12" speaker with Fender-style oxblood grill cloth, t-nuts installed, mount holes drilled... in other words, I want these ready to drop in to my cabs. Any ideas for where to buy these? I hope to buy a standard, stock item (like a 5E3 baffle, sort of), but the only place I can think of for this is Mojotone, and I know there must be others. Thanks, guys!
jimipage
Re: Source for speaker baffle ready to drop in?
Post by jimipage »
I know ampwares ( www.tubeampparts.com ) carries a pretty wide selection of baffles, but I can't say off-hand if their prices are better than Mojo or not. Although I've never had any problems with ampwares, I know many others have big complaints about them, so excercise caution. Maybe call them beforehand or just place your order by phone.
hope this helps!
s2
Post by s2 »
Mojo has a pretty good selection of baffles too. I often buy their 12" Princeton Reverb replacement and they always arrive perfect.
ampdan
Post by ampdan »
+1 on the Mojo.
oldhousescott
Post by oldhousescott »
I believe JD Newell could do this for you as well.
http://www.newellamps.com/
"We put a little quality in everything we build..."
David Root
Armadillo Ampworks
Post by David Root »
I get my cabinets from Will Dyke at www.amprestoration.com, Armadillo Ampworks. He will also do baffles, backplates etc. for any amp. He's in Texas, north of Austin.
bentonar18
Thanks for the help, guys: several of those mentioned already responded!
