EL84 transformers
- gui_tarzan
EL84 transformers
A friend gave me an amp out of a Baldwin organ a few days ago. While looking up schematics for different types of EL84 amps I discovered something interesting but I don't know the reason for it. The organ transformers are both (single pair for the auxilary amp & dual pairs of EL84s for the power amp) PP non-linear and almost ever schematic I've found for a hifi or guitar amp that uses these tubes shows linear transformers.
Why would the organ not use a linear transformer with these tubes and other amps do?
I can't find any Baldwin schematics that use this tube but I have seen others on ebay and found out it's a 54A.
--Jim
Re: EL84 transformers
I do not understand what you are stating in your post here, if you mean that the aux amp(s) run one output tube which must be single ended and the main amp runs two outputs in pp, than yes organ amps of many manufactures do that a lot!!
I'm not clear what you are saying. Did you say there are a total of 6 transformers:
Aux: PT + SE OT?
Main 1: PT + PP OT?
Main 2: PT + PP OT?
What do you mean by non-linear and what leads you to this statement?
Aux: PT + SE OT?
Main 1: PT + PP OT?
Main 2: PT + PP OT?
Maybe Jim meant to say the OT's are not ultra linear types?
Yes, I've understood "not-UL" as martin did.
But... who knows...
But... who knows...
- gui_tarzan
There are two amps on this chassis. One uses a quad of EL84, the other uses a pair. Both are PP circuits and transformers, but they have the standard, non-linear blue/red/brown primary wires. They don't have the extra pair of leads like my Traynor amp transformers have.
It's more or less a philosophical question - why run linear vs non-linear on a guitar amp?
--Jim
It's the use of the term "non-linear" that is throwing people off. What you mean to say is these power amps are non-UL (or non-distributed load) configurations. Nothing says they have to be... for examples of guitar amps that use EL84's without DL OT's, how about Marshall 18W or Vox AC30? The argument against DL usually runs along the lines of it sounds too Hi-Fi for a guitar amp.
- gui_tarzan
Ok, that's fair. By "non" linear I'm referring to the three-lead primary since most people refer to the five-lead as an ultra-linear transformer. Probably not the correct terminology but it's how I separate them in my mind.
--Jim
So, I think you've got a real score on your hands. Lots of promising iron -- enough to build 3 amps!
On a UL type OT the extra two leads are on the secondary winding, not the primary!
Steve, you need more coffee!Stevem wrote:On a UL type OT the extra two leads are on the secondary winding, not the primary!
??? They are on the primary. You need to connect screens to them.
- gui_tarzan
Did someone hack your account Steve?
--Jim
- gui_tarzan
Ok, so the Vox AC30 power amp uses a 50 ohm resistor on the cathodes, is that really enough?
--Jim
