clarostat rv4 pots
lumox0013
clarostat rv4 pots
Post by lumox0013 »
I recently while doing research for the asteroid that Im getting ready to build foud out that all the pots that came with the build ( I traded for ) are linear taper, in fact all the rv4 pots I own (40+) are linear taper. where can i gett audio taper rv4s? is there a build that uses all linear pots where I can use these things? any help app. thanxx guys
Live , Love , Learn
David Root
Re: clarostat rv4 pots
Post by David Root »
PEC RV4 pots are used by quite a few of us. 100K thru 1M available in 10% audio taper. They are well made, N. American manufacture, not Asia, and are in stainless steel so you can't solder to the backs, not that I would ground that way myself anyway.
AES (tubesandmore.com) has them in 3/8" long shafts which are right for most builds but not Express with wooden faceplate--too short then. IIRC they are about $10 each.
