easier PPIMV (Post-Phase-Inverter-Master-Volume) ?
jamme61
Post by jamme61 »
Is it possible to just bleed off signal between the phase inverter coupling caps and the bias resistors? So instead of removing the bias resistors and adding a dual gang pot- I could just bleed off signal with two resistors to ground.(value to be determined) I'm asking not telling, stupid idea? would it work?
Re: easier PPIMV (Post-Phase-Inverter-Master-Volume) ?
That's a common MV. Type 3 in Ken's Trainwreck pages:
http://www.blueguitar.org/new/schem/tra ... _pages.pdf
jamme61
Post by jamme61 »
Yea I've used type 3 but that is canceling the two sides out to lower the volume. I wanted to send the signal to ground- I guess I'm confused about this.
matt h
Post by matt h »
(deleted)
V2
Post by V2 »
matt h
Post by matt h »
(deleted)
