pt /ot from a 25 watt Ampeg what can i build?
Ive got a good PT and OT from a 66 ampeg reverbrocket gs-12R.I would like to build a fender deluxe.the pt had a 3 amp fuse and used silcon diodes.Iman electronics  tech by trade but am new to guitar amps.Thanks
Re: pt /ot from a 25 watt Ampeg what can i build?
You should be able to use those transformers for a Deluxe, but if the PT used a FWB rectifier you'll need to do the same.
Just about any amp that uses a pair of EL84 or 6V6. Lot's of Fender designs, Marshall 18W, Vox AC15, Matchless....pretty long list.  You might even get by with a cathode biased pair of 6L6, like a 5B6, which is a fun build and an amp worth having. Be sure the check filament current requirements.
The 7591s that the Ampeg used are good tubes also .
