built this for "Device Under Test" from the Tonnes
Curranproducer
Post by Curranproducer »
OK- I want to help insure that all of my builds are safe from me goofing them up and frying iron. So I built this DUT power switch thingy form the Kevin O'Conner Tonnes of Tone book.[/img]
Here are the schematic and the wiring layout as well form the book.
so I built this thing, and it it working EXCEPT for the bulbs. should these only come on when the power is failing to get through the DUT? I am getting 120VAC in all the spots that I should, and i have put a couple of things on the power plugs but no bulb light. There is not a clear explanation in the book on what the light bulbs should do IF the unit you are hooking up is running just fine
Curran
Owner of Custom Audio Mutation Recording Studio, Guitar/Amp/Pedal Repair, and Mod center in Akron Ohio
Devout Distortion Worshipper and fan of warm hugs
234-788-6141
vibratoking
Re: built this for "Device Under Test" from the Tonnes
Post by vibratoking »
You don't know how to use it, but at least you have one. :P
See the TAG lightbulb limiter sticky thread. What you have there is just a fancy version of that. https://tubeamparchive.com/viewtopic.ph ... highlight=
Last edited by martin manning on Sat Jun 21, 2014 10:05 pm, edited 1 time in total.
ToneMerc
Post by ToneMerc »
Seems like a real Rube Goldberg way of making it far more complex than it needs to be, not to mention costly.
TM
John_P_WI
Post by John_P_WI »
The bulbs will only glow IF S2 is open (off) and there is load. Without anything connected to the device, the bulbs will not glow. The bulbs act as a large resistance and IF there is a large load such as a short will prevent damage (they would glow brightly in this situation). If the device is connected and the bulb(s) are very dim then S2 can be closed (on) allowing full line voltage to be applied to the device.
Curranproducer
well I was just building it to what Kevin has in his book, NOT trying to make anything harder than it needs to be! Believe me!!!! KISS is a motto I love! HAHAHAHAHAHAHA.
Curran
234-788-6141
Kagliostro
Post by Kagliostro »
OK apparatus test
http://www.youtube.com/watch?v=BhBhWi7c8us
Bad apparatus test
http://www.youtube.com/watch?v=68Zq1sDMbTM
I hope this can clarify the use to you
K
Excellent examples.
Although I don't recall the bulb getting brighter again.
I probably shut it down before that happens.
There is no standby switch in a radio, so the re-glow in the video is likely the result of the tubes coming up in temperature and beginning to conduct some current.
In a guitar amp with a standby you see an initial bright glow as the reservoir charges at power on, then a dimming down to a steady glow reflecting just the filament current.
When the standby is switched on, you will see another momentary brightening as the remainder of the filters charge, followed by a glow that is somewhat brighter than it was with the standby off due to the additional current flowing through the tubes. Be aware that there can be some variation in this behavior depending upon how the standby is implemented. Remember also that with a bulb limiter in, voltages throughout the amp will be low, the cathodes of the tubes will not be at full operating temperature, and it will take more time for the filaments to heat up.
Kagliostro
Is a long time since I saw those video
if I'm not wrong the re-glowing is due to an increase in consumption of the circuit due to the selection of a transmitting station, this push the consumption of the AF part of the circuit, I'm sure also that this depends also on the kind of bulb you are using in reference with the whole circuit consumption
(a 50W lamp or a 100W lamp aren't the same thing)
K
So I plugged a 50W amp into a bulb limiter with a 60W bulb and switched the main power and standby at the same time. Result: A bright glow which diminished to a dim glow after a few seconds, then after another 15 seconds or so an increase in brightness. Turning the standby off returned the bulb to a dim glow.
Kagliostro
the inrush current that charges filters cap
tubes has reached theyr function point (heaters are heat)
the tubes aren't sucking current any more
I think that a 75W bulb will act a bit different
I suppose it to glow and dim at start then no more glow or only a very small amount
K
Kagliostro wrote:I think that a 75W bulb will act a bit different.
I suppose it to glow and dim at start then no more glow or only a very small amount.
No, quite the opposite. I just tried it with a 75W. The initial dimming is more pronounced, and then the re-glow is much more noticable.
Kagliostro
Sorry
I wrote it backwards
K
Very interesting...... :idea:
