ID this Tube??
David Root
ID this Tube??
Post by David Root »
I think it's a 5AR4, but could be wrong The plates and double D top getters look like an old Mullard but it doesn't have a hole in the bottom of the base pin nor the etched date code. I thought RCA did not manufacture 5AR4s before the early '70s. It's about the size of a '60s GE but no copper plate edges.
I know that just because it is marked "made in USA for EICO by RCA" doesn't necessarily mean that's true. I would believe the 58-52 date code though.
I'm stumped.
Re: ID this Tube??
Post by Stevem »
I do not think its a full wave recto like a 5ar4, 5y3 or 5v4 and such as the there seems to be only a single plate mass, I think its a half wave recto of some sort.
Get on the tube world site and scout around as they have good pictures of all the tubes.
David Root
Re: ID this Tube??
Thanx for respnding, Stevem. My pics don't show the plate structure too clearly, I was focusing on the lettering on the base.
Here is another pic that to me looks a lot like a Mullard 5AR4. The flash is obscuring most of the space between the plates, but there are two plates with a support rod in between them.
Firestorm
Re: ID this Tube??
Post by Firestorm »
I have a Mullard logoed GZ34 that looks exactly like that: base bigger than glass and no hole in the guide pin. But mine does have an etched Blackburn code. I think Philips was pretty fussy about that. Are you sure there's no trace of a code? Maybe by the 70s they gave up on that for tubes made for other companies.
David Root
Re: ID this Tube??
Thanx Firestorm, that helps, I have also seen pics of old Mullards that had no base pin hole.
Mine is date coded last week of '58, (58-52) and I have a pair of '60 Mullard EL37s (B0J) that have no hole in the base pin either.
It looks like the so-called "fat base" Mullard except the upper mica is different. It has double D getters like the fat base Mullard.
But I can find no trace of a Philips etched code, or anything at all on the glass.
Re: ID this Tube??
Post by Stevem »
If that main plate structure mass is located in the dead center of the tube, its a half wave recto.
still hard to tell a 3 dimentional thing from 2 dimentional photo!
Gibsonman63
Re: ID this Tube??
Post by Gibsonman63 »
I have read that if you put it in the freezer for a while, you will be able to see the outline of where the printing was when you pull it out. I have not tried this.
Re: ID this Tube??
Gibsonman63 wrote:I have read that if you put it in the freezer for a while, you will be able to see the outline of where the printing was when you pull it out. I have not tried this.
That has worked for me. Chill it, then breathe on the glass.
David Root
Re: ID this Tube??
Thanx for the freezer tip. I just tried it, but no joy. There is a small area that shows what look like scratch marks, but that is all.
Stevem, there are definitely two plate structures, separated about 1/8" in the center. In the middle of that space there is a stout support rod.
Re: ID this Tube??
David Root wrote:Thanx for the freezer tip. I just tried it, but no joy. There is a small area that shows what look like scratch marks, but that is all.
Sell it as cryogynically treated now for big bucks :lol:
danman
Re: ID this Tube??
Post by danman »
Could it possibly be a Matsushita tube. They were set up by Mullard and I know that there EL34's look identical to a Mullard except for the guide pin hole. I see RCA branded tubes on Ebay quite frequently being sold as Mullards but are actually Matsushita tubes.
Re: ID this Tube??
danman wrote:Could it possibly be a Matsushita tube. They were set up by Mullard and I know that there EL34's look identical to a Mullard except for the guide pin hole. I see RCA branded tubes on Ebay quite frequently being sold as Mullards but are actually Matsushita tubes.
Very possible I have some RCA jap '6ca7's Look exactly like mullards.Except for the base pin Good tubes
danman
Re: ID this Tube??
Post by danman »
I agree cbass, very good tubes and the prices are still reasonable!
David Root
Re: ID this Tube??
Thanx again guys, maybe it is a Matsushita. Some Pics I've seen of those are not "fat base" types. Other ones that are "fat base" seem to have an "X" in the top of the glass, which mine doesn't have.
If it is a Matsushita then all the writing including the date code 58-52 is probably a fairy tale, as it seems the Matsushitas are from the '70s from what I can see from the web searches I've done. OTOH that would explain the lack of the etched Philips date code on my tube.
