Cleaning Fluke tip leads?
amplifiednation
I've been having some trouble with my Fluke. Despite the new batteries...it just sometime will not take a reading.
Are tips something that should be cleaned? Could they have a strange film or some reason preventing taking accurate? I'm ready to just buy new. Ones...but figured I would ask
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
eniam rognab
Re: Cleaning Fluke tip leads?
definitely take some sandpaper and sharpen up those tips before you buy new ones, they can get corroded for sure
good luck!
good luck!
Clean the probe tips and meter jacks with a bit of contact cleaner on a Q-tip. Some probes have removable/replaceable tips. Pull them out with needle nose pliers, wipe them with contact cleaner, and reinsert.
hold the sandpaper! Like the putz-maniacs around here pressure washing their stone driveways, it is just too aggressive, makes things exponentially worse over time.
As Martin said: contact cleaner.
Some will leave a residue and you have to follow with a cleaner for the contact cleaner!
Tubetastic
Is there a possibility theres an issue with the lead itself - a break in the connection inside. Like when a guitar lead goes.
amplifiednation
Yes there is a possibility the lead is compromised, but I can get readings with different parts of the tip.
I'll try the contact cleaner first. The leads are pricey. There's few things more frustrating when your test equipment...well...isn't testing. Thx Martin
Oh and yes, tried the battery first. I called Fluke and they recommended new leads. It's an 87-V that I got used. It's a great meter but it's got some mileage on it. I guess they are supposed to go for 10-20 years....
Thx guys
Thx guys
Amplified Nation
@ampnation
@ampnation
Rosin core solder being essential for good solder joints, your probe tips are constantly being stuck in sticky rosin residue. Contact cleaner doesn't really dissolve rosin residue, but flux remover does. Mouser sells a product from MG Chemicals called Flux Remover for PC Boards that dissolves old and new rosin so you can wipe it away. It makes your repairs look like factory work. It's great for cleaning up used/scavenged parts before you reuse them. It cleans probe tips like magic. It's like a handyman in a can....
Anyway, it's good stuff.
A Fluke lead will stretch if it is open. If you gently pull the lead, starting at one end and working your way to the other, the rubbery insulation will stretch revealing the open.
I agree sandpaper bad. 0000 steel wool works well, obviously no more than necessary. Always some in my solder box, use it to clean old cap and resistor leads.
amplifiednation
Excellent. I'll try this stuff. I've been meaning to get some flux remover for a while now, but my trusty can of acetone works so well....despite it's drawbacks. i actually did a very slight swab with the acetone but I was hesistant to use too much and have it dissolve the plastic/rubber lead partsarmillary wrote:Rosin core solder being essential for good solder joints, your probe tips are constantly being stuck in sticky rosin residue. Contact cleaner doesn't really dissolve rosin residue, but flux remover does. Mouser sells a product from MG Chemicals called Flux Remover for PC Boards that dissolves old and new rosin so you can wipe it away. It makes your repairs look like factory work. It's great for cleaning up used/scavenged parts before you reuse them. It cleans probe tips like magic. It's like a handyman in a can....
Amplified Nation
@ampnation
@ampnation
vibratoking
35 years in the industry and I have never seen or heard of a probe that stopped working due to tip corrosion. Lot's of bad wire and connections, but not tip corrosion. I am doubtful.
eniam rognab
60 grit! do it!
i meant polishing sandpaper just to sharpen the tips up a lil..... get em shiny but nevermind
VK: this is another technician vs engineer thing, i have seen some NASTY meter leads from testing battery terminals that were corroded and benefited from a polish. you never know what is out there....
This place sells some great test leads.
Their shipping seems excessive on just a set of probes, but I contacted them and they told me to call them and they would charge the appropriate amount for a small order.
http://www.probemaster.com/index.php?cPath=2
Probemaster
I'm sure staying away from the Probemaster!
Tubetastic
Sure has a ring to it...
