I've just finished my first amp build. A clone of the Selmer Little Giant MKIII. It is working pretty well, it is certainly loud, and plays very similar to the originals I have tried. I'm yet to house it, but here are a couple pics of the build.
Here is the schematic:
One thing I am worried about is the voltage rating of (what I assume is) the 25uf cathode bypass cap on the single EL84 power tube going from Pin 3 to ground. The rating of that cap is 450v. Are they not usually something like 25v?
I noticed that at full out volume there was some slight cutting out when doing second-fret hammer-ons. After first testing the amp, which lasted about an hour, when I came to turn it on again later, the output was much much lower, and breakup occured far too early. After replacing the tubes one-by-one it was the EL84 that was at fault. Replaced it with another of the NOS Genalex GL tubes and it was back to normal. I haven't had the chance to play the amp since then, but I guess that it could have just been a bad tube, but I'm a little skeptical. Also, whilst I know that power valves are supposed to run the hottest, it did seem to be hotter than it should be.
I'm not sure what else could cause this. The filter caps are 400v each. I could only find a 120r resistor for the 130r resistor on pin 3 of the power valve. And for the 5.6k resistor on the filter caps I have a 4.7k resistor. Might those be an issue?
thanks,
Edward
