Combining dry and reverb outputs
Erik
Post by Erik »
I have a "66" Guild amp the has both dry and reverb outputs. I am considering running both 8 Ohm output to either 1 or 2 8Ohm speakers so that I get the reverb out of the same speaker as the dry sound. Is this no no for the amp or output transformers? Thanks,
:shock:
Leo_Gnardo
Re: Combining dry and reverb outputs
Post by Leo_Gnardo »
Highly unrecommended to combine the outputs of power amps - it looks like that's what you're proposing. In amps of this type, where one speaker handles the dry, and another speaker only reverb, I enjoy the space effect. If you have to mic up for PA or recording, one more mic, geez what a hassle.
Can you post a schematic to that amp?
Erik
Schematic
Post by Erik »
Really just trying to eliminate equipment, trying to use a 1-12" cab instead is a 2-12" cab. Thanks again for the input.
Ken Moon
Post by Ken Moon »
That is one cool amp.
Here's a pic I found:
http://www.el34world.com/Forum/index.ph ... ttach=9780
Erik
Yeah that's it
Post by Erik »
Here's what mine looks like now. Pics kind of washed out, Maybe I can find one that is a better color representation.
Erik
maybe this
Post by Erik »
Here
Wow!
Insane cab for that.
Tell us about your amp and cab! :D
Amateur hour here....it looks to me like point A is where the dry signal is either sent to the reverb or bypasses the reverb. I don't know what happens when you do it, but it looks like if you jumper the reverb switch so it is connected to both poles (both "on") at the same time, you get the wet and dry signal together. It calls for a different type of switch.
Please don't hold me accountable if that causes the amp to blow up or some other undesirable thing happens. Really, I wouldn't try it on an antique like this. You've been warned.
Leo_Gnardo
Re: maybe this
Erik wrote:Here
Yow WOW! She's a stunner!
I can think offhand of only one semi-common amp that has the feature of separate power amps & speakers for dry & reverb - the Ampeg Echo Twin. There IS a toggle switch that selects 2 modes, separate, or combined signal going to both speakers, and the switching is done at a preamp level, not mixing the power amp outs. You may want to find an Echo Twin schemo and compare it to your Guild. One thing that may work in your favor, it seems in the 50's-60's Ampeg, Guild and a couple other NJ manufacturers shared a number of ideas and personnel.
Short of making any amp mods, you might consider making a 12 + 8 or 12 + 5 cab and let the smaller speaker handle the reverb. Sano did that in one of their accordion-oriented amps with a 15 and two 8's. Sano was also part of the NJ amp "brain trust."
Firestorm
Post by Firestorm »
Phil_S wrote:Amateur hour here....it looks to me like point A is where the dry signal is either sent to the reverb or bypasses the reverb. I don't know what happens when you do it, but it looks like if you jumper the reverb switch so it is connected to both poles (both "on") at the same time, you get the wet and dry signal together. It calls for a different type of switch.
The reverb switch looks like it's labeled crooked. When it's "off" it sends the speaker - driven reverb to the amp for the reverb speaker; when it's "on" it picks up the dry signal at point A and puts that through to the second speaker. Since the reverb is driven by the main speaker, there's no way to eliminate a speaker and still have reverb.
Erik
My AMp
Post by Erik »
Hey Structo,
As far as I can tell, it's a '66 Guild Thunder 1 w/reverb. Got it from a friend years ago in Va Beach. All that has been done internally is the replacement of a cap or two and the power lamp. I changes the pre-amp tune for one out of a Fisher 800 and think it needs replacing cuz it doesn't sound right anymore, but I have a couple of other projects at the moment so it sits, for now. I built the cabinet using scraps I had lying around the shop, yes scraps. The veneer wasn't long enough to wrap the whole case so I added trim where necessary. I still have to give it a few more coats of finish. It needs the multi-can caps replaced too, I think.
Thanks for all the advice think I will just run a 2-12 cab. to be safe. My main set-up right now is a Silvertone console hi-fi amplifier with a Digitech 2120 pre-amp/effects unit.
Cheers!
What a beautiful cabinet. :)
