I'm looking for the schematic of a SS High Voltage (may be Mosfet) Transformerless Reverb circuit to be put in tube amps
Someone has seen something like that ?
K
Someone has a schematic for a SS HV transformerless reverb
- Kagliostro
Re: Someone has a schematic for a SS HV transformerless reverb
Pedal in the effects loop?
If it's to be solid state, why high voltage?
- Kagliostro
I forgot to say
the use is to mod existing Tube Amp, no external pedal
K
K
If it's transformerless then the tank input is low impedance and I seriously doubt it requires high voltage drive signal.
Did you think this topic over thoroughly before posting?
- Kagliostro
I understand near nothing about SS circuitsDid you think this topic over thoroughly before posting ?
so I've asked
K
- Milkmansound
here is an easy idea:
buy a holy grail nano - gut it - place it between the input jack and V1 - power it off 9V (either from the heater supply or a small PSU in the amp)
and you're done! $99 solution
- Kagliostro
That is one solution, thanks for the suggestion, but there are more
http://surfybear.weebly.com/new-pcb-and-kit.html
http://surfybear.weebly.com/fet-reverb---project.html
http://surfybear.weebly.com/uploads/1/3 ... reverb.pdf
K
K
You would want a high impedance input tank, Ampeg and a few others used them, Acutronics 800 ohm or 1600, can't remember which though. Using a LND150 for recovery, maybe one and an IRF820 in source follower for drive. I had a circuit someone in South Korea did that looked promising but lost it when my computer crashed. Have not been able to find it since, was a blog, no time yet to come up with my own circuit. It can be done, other than that I can not be much of help.
