Uni-Vibe
sergio
Uni-Vibe
Post by sergio »
Hi , I would build the Uni-Vibe pedal and I found this schematic!
It's enough close to the original?
Someone knows the characteristic of the photo-cell or what type I can buy?
Sergio
John_P_WI
Re: Uni-Vibe
Post by John_P_WI »
rogb
Re: Uni-Vibe
Post by rogb »
This is what I built, a NeoVibe. it kills!
http://www.generalguitargadgets.com/com ... gory_id=19
I ordered the parts from Small Bear.
Here is the BOM for the NeoVibe.
Also had some help from RG and the crew on here:
http://www.diystompboxes.com/smfforum/
Turret
Re: Uni-Vibe
Post by Turret »
Sergio, see attachment
This is a set of replica Univibe files I did while ago
As to my knowledge we have several Univibe schematic. Basic topology is the same, just sometimes parts values are different - mainly in shifter stages
Check out the tread I've started over FSB, lot's of valuable information, including transformer spec, LDR choice and Hendrix's UV spec
http://freestompboxes.org/viewtopic.php ... it=univibe
Turret
Re: Uni-Vibe
Post by Turret »
The rest of the attachments, I can only add 5 per message
drew
Re: Uni-Vibe
Post by drew »
sergio
Re: Uni-Vibe
Post by sergio »
wow... thanks guys!!
S
