It takes the 6.3V heater supply and dumps it down to 5-13VDC
http://www.mojotone.com/amp-parts/Pedal ... srf0KUVVmj
think this might be juts the ticket for getting DC onto sensitive preamp tubes, but I have no idea what the output current is. I have an email into them and will post more when I hear more.
anyone tried this mojotone product?
- Milkmansound
Re: anyone tried this mojotone product?
Looks like a run-of-the-mill voltage doubler circuit with an LM317 or equivalent regulator chip and adjustable output. I would question whether that circuit has sufficient capacitance and filtering to make for truly quiet DC filament work. Depends on how big those caps are.
Take care that an inceease in voltage means a decrease in current, so your heater's winding could be not enough for the whole amp.
On my latest build, I just used a bridge rectifier and a big cap (10,000uf) on the 5VAC taps for the DC heaters on the preamp tubes. It works out to about 5.5VDC, which seems to work fine (see pic - the square rectifier and cap near the power section is for the preamp heaters).
https://tubeamparchive.com/viewtopic.php?t=23439
- Milkmansound
thats a good point - but the caps can always be upgraded to a higher value. I ordered one up so we'll see what it is in a weekColossal wrote:Looks like a run-of-the-mill voltage doubler circuit with an LM317 or equivalent regulator chip and adjustable output. I would question whether that circuit has sufficient capacitance and filtering to make for truly quiet DC filament work. Depends on how big those caps are.
I would just want to run 1 or 2 preamp tubes off DC. Reverb driver and PI can stay with AC - so a 1A supply should be ok if the filtering is ok
Yeah, it's hard to tell what those caps are on the board, so maybe they are 4,700uF 25VDC caps so may be sufficient.Milkmansound wrote:thats a good point - but the caps can always be upgraded to a higher value. I ordered one up so we'll see what it is in a weekColossal wrote:Looks like a run-of-the-mill voltage doubler circuit with an LM317 or equivalent regulator chip and adjustable output. I would question whether that circuit has sufficient capacitance and filtering to make for truly quiet DC filament work. Depends on how big those caps are.
- Milkmansound
heard back from mojo - they said not to use the board for this, so I removed them from my order
supposedly hoffman makes something like this that will work
If you have an extra 5VAC tap available, use my setup from above -- it works great for this and is cheap.Milkmansound wrote:heard back from mojo - they said not to use the board for this, so I removed them from my order
