bias
Smokebreak
bias
Post by Smokebreak »
I'm working on a 50W 6L6 fixed bias and built my bias board for running off HT leg, before I realized the PT I'm gonna use has a 50V tap. I was just gonna change the 220K before reverse diode to 470r, or so, and use the 50V tap, but it got me thinking..Is there a reason why one way would be more advantageous than the other?
Andy Le Blanc
Re: bias
Post by Andy Le Blanc »
less parts, no coupling cap, lower voltage means cheaper lower watt parts w/50v
lazymaryamps
Re: bias
If this is a FW rectifier configuration the part count is about the same. True the first dropping resistor needs to be stout if the bias is taken from the HT. If the 50V tap is actually a separate winding (which is sometimes the case), that would reduce any asymmetry that might be created if bias is taken from one side of the HT winding.
Smokebreak
Re: bias
Sorry, yes FW ala Express. Thanks!
Firestorm
Re: bias
Post by Firestorm »
If you ever decide to power scale the amp, the separate tap or winding has lower impedance so the bias supply will respond faster to B+ adjustments.
Andy Le Blanc
Re: bias
thats a little gem right there
lazymaryamps
