overtone wrote:I like grid leak on 6SJ7s.
There is something odd about the cathode ground drawn tied to the "top" of the 0,05 g2 cap - surely that link should to be "after" the cap to make it of any use?
In the GA40 I have here there are two 6SJ7s before hitting the PI. These preamp coupling caps on the GA40 are lower (than the GA20) at 0,01 and 0,02.
Good catch on the .05 cap. It is a drawing error. Thanks.
I built a modified single channel GA20 a few years ago and what you see is how I ended up dressing it. It is a one trick pony, it is one great trick!
What is the affect of reducing the coupling cap from .05 to .02 or .01?
Also, I'm giving serious consideration to matt h suggestion to put the pentode in as a recovery stage after a c/f and I'm thinking that's where I employ the switch, as a bypass to the pentode. Thoughts on that?
Also #2, I've got two empty holes on the rear of the chassis. I'm wondering if I can move the output jacks towards the rectifier and use one hole for a MV pot (yay, I can use whatever I want) and the other hole for another switch of unknown use at this point. The question is a layout question, as I'm not sure how close I can come to the rectifier socket before it gets to be a problem. Pictures...I suppose I'd be willing to drill the back panel if there was a good reason. There is adequate room over near the power tubes. I'm not wedded to the two sockets I wired for the 6L6's. I can shift to the two closest to the OT and use the one near the edge for the PI. I'm thinking that may be an improvement if I want to mount a pot.
On the OT, terminals 4, 6, and 8 are the 4-8-16z secondaries, and terminal 2 is the common. Terminal 10 is the B+ CT and primaries are terminals 7 and 9. I can tuck the primaries in close to the winding and keep them on the chassis.
I'm looking for opinions on layout.
Thanks!
