Panel text
Panel text
Hi all
Quick one, hopefully.
I've got the below Ceriatone brush aluminum panel but I would like to remove the circled text.
[img:671:495]http://s22.postimg.org/j81zfj535/Paneltxt.jpg[/img][/url]
What would be the best way to achieve this?
Thanks!
Thanks!
- Reeltarded
Re: Panel text
A label. Black tape. Umm a torch. Thick red lipstick. Sand blaster.
Re: Panel text
The stuff I put in my dishwasher, Citrishine, or somesuch, is slowly removing all the screen printing from my glassware.
Re: Panel text
I'd just leave it as-is.
Re: Panel text
Another vote for leave it. Whatever you do short of stripping the whole panel, it's going to show. If you are set on "fixing" it, masking tape and flat black spray paint? It is still going to flash.martin manning wrote:I'd just leave it as-is.
Re: Panel text
... or put a mod switch there
or if you just can't live with it there taunting your OCD, get a new panel made! Pricey, but we do what we must for our amps.
- Milkmansound
Re: Panel text
in those situations I usually leave the switch in the hole, hooked up to nothing
Re: Panel text
I bet you could still get some people to tell you which way has less hum.Milkmansound wrote:in those situations I usually leave the switch in the hole, hooked up to nothing
Re: Panel text
Simple, install a switch and death cap.
Worked for generations of musicians before safety became an issue..............
vibratoking
Re: Panel text
Taunting your OCD...that's a good one.
Speaking words of wisdom, let it be.
- Reeltarded
Re: Panel text
If we are filling the hole I vote knob. Vote knob.
Re: Panel text
I'd be tempted to fit a switch that does nothing.
A magic switch that adds that little something.
A throttle plate di-flange grundler !
Or just leave it as is.
Why Aye Man
Re: Panel text
Structo wrote:Simple, install a switch and death cap.
Re: Panel text
Cover it with your build "badge/signature".
Re: Panel text
Sorry, but when I read that I hear Lawrence Welk in the electric chair. " A one and a two and a ZZZZZZZZT.........
LeeMo
LeeMo
