Scooter Thomas wrote:Well, I knew joining TAG would force the issue. I gotta build an amp!
Welcome. Be careful what you hope for. Amp building is addictive. After you build one, you'll never get the monkey off your back. You can, however, moderate how often you need a fix.
I mostly play a JTM45. I don't "need" a guitar amp, but I could use a Rocket or a 5E7 or 5E8A. What I do need is a Dynaco ST-35 or maybe ST-70.
That's not right. Everyone needs another guitar and another guitar amp. Stop kidding yourself. This isn't about what you can use. After you build one, you'll understand this truth better. It's the Dynaco's that are nice to have. Either way, learn how to do it and you can build what you like.
Still, I think I'll build a 5F1 to start. I'm thinking I want the Triode kit with the 15w OT and a KT66 (10w cathode cap) with a 10" speaker (Weber 5F2A cab.)
This is a good place to get your feet wet. A relatively simple amp like this will still teach you more than you imagine.
Room for a 3-way rotary for impedance select?
Will a KT66 perform ok in this circuit?
Orange drop or Mallory?
Anything else I should consider?
Cliff covered this nicely, IMO.
BTW, I solder by numbers. I can discharge caps, I have a snuffer stick. I have a lightbulb limiter I built and used when I swapped my JTM PT. I'm not much of a circuit jockey and my limited tools are abysmal but functional. I don't have a bench with a variac and iso transformer but I can safely wire a champ, I think!
You don't need fancy tools and diagnostic equipment to get started. Everyone starts with the bare essentials and soon you'll stop soldering by the numbers!
Get going on this! We want to see pictures of what you do.
