However, when I turn up the (pre-phase inverter) master volume on the 12AX7 channel, I'm still getting lots of HISSSS. I thought this was an input jack grounding issue, but I re-worked those and still am suffering from hiss. Cleaning up the wiring and moving some grounds helped with the clarity of the channel, but I'm still getting a lot of preamp hiss with the master up. With the gain up and the master down there is surprisingly less hiss than with the master up and the gain down....odd. Again, killing the EQ kills the hiss, as does killing the gain and master volumes...so I'm lead to believe the problem indeed lies in the preamp section.
I'm at a loss at this point.... Would an oscilloscope reveal where the noise is coming from? I've done all the solder re-flowing and carbon comp resistor replacing that I can, and am stuck as to what else might be the problem. I know I'm beating a dead horse here, but any input is greatly appreciated (so long as it doesn't produce more hiss). Ah, that was bad....but I'm sleepy.
If I can't figure out what's up in the next week or so I'll have to take it to a tech, or someone with a scope...I've reached the end of my meager abilities and knowledge.
THANKS!
