Got a vintage SVT in today. Guy says it is the first year they made them, and has been converted to 6550's. I don't know what that means exactly in this case.
It has a whitened 6550, with it's 3.6 ohm 5W plate resistor burnt to a crisp. One of the other resistors has been replaced with a 5 ohm 5W, and the other four are original 3.6 ohm. AFAIK 3.6 ohm 5W is no longer available, and Fliptops sells a 5.1 ohm 6-pack for vintage SVTs. Would this be the way to go? And shouldn't it have been done when the 6550s were put in? That's what I see on one of the 6550 equipped schematics.
SVT with 3.6 ohm plate resistors
- Leo_Gnardo
Re: SVT with 3.6 ohm plate resistors
The white 6550 has either decided to be a milk bottle or much more likely is now an air tube as opposed to a vacuum tube, so can it and get a working one. I've seen 3.6, 4, 5, and 10 ohm resistors in the plate function. Value isn't really all that important and I expect would be hard to tell the diff even if you had a Heinz 57 variety of R's there. They are supposed to act as fuses if an output tube shorts. Not much of a sonic signature, except an open-circuit one will play you the sound of silence.Randall wrote:It has a whitened 6550, with it's 3.6 ohm 5W plate resistor burnt to a crisp. One of the other resistors has been replaced with a 5 ohm 5W, and the other four are original 3.6 ohm. AFAIK 3.6 ohm 5W is no longer available, and Fliptops sells a 5.1 ohm 6-pack for vintage SVTs. Would this be the way to go? And shouldn't it have been done when the 6550s were put in? That's what I see on one of the 6550 equipped schematics.
FWIW I get mine from Mouser. If you need to get a bunch of other items, tools, shop supplies, that may be a place to go shopping.
gingertube
I thought they were supposed act as anode stoppers to supress parasitic oscillation ???Leo_Gnardo wrote:.. They are supposed to act as fuses if an output tube shorts...
Ian
- Leo_Gnardo
Waylll, I s'pose you could wrop a swatch of wire 'round each of em, hey if they're Wire Wound doesn't that also act as a micro choke..... And have seen a tiny inductor in McIntosh tube amps. Trick question Ginger! My best "educated" guess is - they're dual purpose.gingertube wrote:I thought they were supposed act as anode stoppers to supress parasitic oscillation ???Leo_Gnardo wrote:.. They are supposed to act as fuses if an output tube shorts...
Ian
Have seen some old SVT with carbon comp in that position. To enhance the smoke factor when the output tube shorts.
I stop parisitics best with Ivermectin.
For those who may care, Randall has his question and more answers at Music Electronics Forum too.
