neon pilot wiring
andrew
neon pilot wiring
Post by andrew »
Hi all, I have a 120v neon pilot lamp wired to a two post carling on/off switch. When ON the amp powers up but the lamp goes off. When the switch is OFF the amp doesn't power up but the lamp comes on. I'm flummoxed. Any help please. Thank you.
JazzGuitarGimp
Re: neon pilot wiring
Post by JazzGuitarGimp »
Rewire so that one wire from the lamp goes to one wire of the PT, and the other wire from the lamp goes to the other wire of the PT.
LeftyStrat
Post by LeftyStrat »
Or label it an OFF indicator. :D
Sounds like it's wired to the opposite end of the switch as the PT. It should be on the same side.
andrew
Post by andrew »
thanks Jazz, works correctly now.
Deric
Post by Deric »
LeftyStrat wrote:Or label it an OFF indicator. :D
8)
Deric®
love that! off indicator.
