Delete post.
67Mopar
Delete post.
Post by 67Mopar »
67Mopar
Re: Cornford RK100 rebuild.
Post by 67Mopar »
JazzGuitarGimp
Re: Delete post.
Post by JazzGuitarGimp »
Wow, that's poetry in motion!
67Mopar
Re: Delete post.
Post by 67Mopar »
JazzGuitarGimp
Re: Delete post.
67Mopar wrote:The buss ground is a mess! Something that I find odd is that the AC ground isn't secured in a dedicated position on the chassis?
Oh yes.... Of course. How silly of me! I take back all the good things I said! :lol:
67Mopar
Re: Delete post.
Post by 67Mopar »
sepulchre
Re: Delete post.
Post by sepulchre »
Beautiful work! Have you considered trying it without grounding the pot casing?
67Mopar
Re: Delete post.
Post by 67Mopar »
sepulchre
Re: Delete post.
Post by sepulchre »
I built an amp that showed the cases grounded and I didn't - no noise, so what the heck, I left them.
67Mopar
Re: Delete post.
Post by 67Mopar »
sepulchre
Re: Delete post.
Post by sepulchre »
Or the holes were pre-drilled and they put some tape on them when they painted? Just a thought.
Star sounds good though.
Roe
Re: Delete post.
Post by Roe »
67Mopar wrote:
sepulchre wrote:Beautiful work! Have you considered trying it without grounding the pot casing?
I haven't tried that yet. Is it mandatory that I ground the backs of the pots?
no its not mandatory if they are grounded to the chassis anyway
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Re: Delete post.
I have used a Dremel tool to remove the powder coat around holes that are to be ground points.
Nice tag strip build.
When you get it going, if you get noise you could take a test lead with alligator clips on each end and provide a chassis ground at suspect grounds to see if the noise goes away.
Just don't clip it to a B+ node :shock:
67Mopar
Re: Delete post.
Post by 67Mopar »
Re: Delete post.
You keep your amp plugged into a variac for it's.. I don't understand that.
Whatever purpose you think you are serving by that IS OF NOT A SINGLE USE. The amp is deadly with a 1A fuse, a 2A fuse, a 3A fuse. A 10A fused switch between you and your electrical box just means the 20A service won't trip when you say hello to baby Jesus. Your local HT will go a long time before the 10A.
At least your heirs will have a variac.
The only safe method of working in the amp with it running is to follow 1 basic rule: NEVER become ground. There are many rules that all cover that rule from all angles.
50k pot for mid extension works just as you would expect. More range.
