Plug & Tweak
VacuumVoodoo
Plug & Tweak
Post by VacuumVoodoo »
This is my approach to making amps on PCBs a little easier to tweak. When done I secure the components with a small drop of glue.
Hope some of you may find it useful.
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
Re: Plug & Tweak
GREAT looking stuff, Alexander. Moar photos!
Gaz
Re: Plug & Tweak
Post by Gaz »
Maybe I'm a little slow this morning, but I don't get it.
Re: Plug & Tweak
Gaz wrote:Maybe I'm a little slow this morning, but I don't get it.
To me it looks like you have IC sockets or other type of socket that the box caps can slide into held in place with glue when done tweaking. (above R27 and another on the right side).
vibratoking
Re: Plug & Tweak
Post by vibratoking »
He's using what look like 0.1" center sockets. These sockets have a standard opening size that normally match nicely with component leads. You just insert the component leads into the socket openings. Easily swappable. Glue them down for 'permanent' installation when you have decided what value you like best. Been done on PCBs for many, many years. This PCB just happens to be in a guitar amp. Of course, all the magic is lost when you use a PCB in a guitar amp!!! :P
VacuumVoodoo
Re: Plug & Tweak
Correct. DIL IC sockets. For stationary use the caps will stay in the sockets without problems. If the amp is to go on the road then securing the caps with glue is recommended.
Ah yes, I use special white magic glue to offset PCB magic killing properties :twisted:
Aleksander Niemand
Zagray!-review
Colossal
Re: Plug & Tweak
Post by Colossal »
One word....
Bad. Ass. :P
Re: Plug & Tweak
Oh, MAN, that's fine-tastic.
What's the trimmer on V1?
VacuumVoodoo
Re: Plug & Tweak
That's a heater hum cancellation trimmer, the wiper is on DC offset. It's on V1 because that's where sensitivity to any hum and overlayed rectification spikes is highest. This way, even when dimed all you'll hear is white noise but no hum or buzz. DC offset on heaters is for the sake of cathode followers and phase inverter o keep heater to cathode voltage difference below allowed max.
Aleksander Niemand
Zagray!-review
Re: Plug & Tweak
Nice idea for those Wima caps.
I have used them before in pedals but not amps due to the short leads.
Socket makes sense, quick change presto! :D
Cliff Schecht
Re: Plug & Tweak
Post by Cliff Schecht »
I do this same thing in pedals.
Aleks that amp looks fantastic inside (and probably outside too) :).
Cliff Schecht - Circuit P.I.
mr_hankey
Re: Plug & Tweak
Post by mr_hankey »
Structo wrote:Nice idea for those Wima caps.
I just solder some extra leads on them:
[img:1011:319]http://i13.photobucket.com/albums/a280/ ... G_1040.jpg[/img]
It's probably not 100% as mechanically reliable as other caps, but definitely good enough, IMO.
VacuumVoodoo
Re: Plug & Tweak
Cliff Schecht wrote:I do this same thing in pedals.
Didn't I show it already sometime in 2011? Anyway, here it is..
Aleksander Niemand
Zagray!-review
Re: Plug & Tweak
Sweet!A work of art Sounds killer
