AB763 Build Completed
fusionbear
Been away for a while. But here is a new build I did by the seat of my pants... Just a AB763 preamp with a KT88 power section PT is a Dynaco Clone P782S, OT is a Classictone 40-18067, Choke is a 40-18058
It sounds really sweet...
http://s169.beta.photobucket.com/user/f ... mp%20Build
[IMG:640:480]http://i169.photobucket.com/albums/u223 ... 50a1db.jpg[/img]
[IMG:640:480]http://i169.photobucket.com/albums/u223 ... 622ec2.jpg[/img]
[IMG:640:480]http://i169.photobucket.com/albums/u223 ... 376c58.jpg[/img]
Learning to learn...
Re: AB763 Build Completed
Very cool build!
PEC pots are the best!
Cool indeed, and with space left for a reverb.
Nicely done.
Congrats!
Nicely done.
Congrats!
Horacio
Play in tune and B#!
That P-T-P wiring looks great. Really nicely done!
Awesome, Bear! How daring, for you to build a Fender stylee!
Headroom must be huge with those 88s. Can you get dirty before rattling windows?
Hey, true point-to-point !
Nice to see this old timey method being used.
Good job.
reddog Steve
Good job.
reddog Steve
jujudubluz
looks great,
do you have clips? what kind of power section did you used?
"less is more" mies van der rohe
Beautiful work.
That puppy's got to be scary loud.
fusionbear
Thanks for all the kind words! Yes, it can get pretty loud, but still not as loud as a regular Twin. It is putting out about 65 watts. I built it for clean tones. I did crank it and it does get some nice crunch, but that was not my intention for this amp. I built it as a "sister" to my JTM45/100 build that I also primarily use for clean tones.
The PT puts about 565v on the plates of the KT88's. The preamp voltages are stock, maybe just a little lower (-2 to -10 vdc on the B+ after the PI). It sounds really sweet. Instead of a normal bright switch, I used a three way selector: 82pf, 120pf, 150pf. It was fun to engineer it "on the spot".
The power section is "book stock" standard LTP PI. The Grid stoppers on the KT88's are 1.5K. I have plenty of Bias voltage available if needed.
The amp sounds like a standard Fender amp. Very different than my JTM45/100 build. That amp always has a glassiness on the high end ala Hendrix. This amp is pure Fullerton/Bakersfield tone...
jujudubluz
jujudubluz
Meant Bright switch, excuse my ignorance but what LTP PI means?
jujudubluz wrote:Meant Bright switch, excuse my ignorance but what LTP PI means?
LTP PI = long tail-pair phase inverter
http://www.aikenamps.com/LongTailPair.htm
Long tailed pair phase inverter. Or Schmitt inverter.jujudubluz wrote:Meant Bright switch, excuse my ignorance but what LTP PI means?
You beat me to it!NickC wrote:jujudubluz wrote:Meant Bright switch, excuse my ignorance but what LTP PI means?
Next time!
jujudubluz
