If you use two 100 ohm resistors as your heater center tap, do not use the power transformer heater center tap wire and visa versa
What is the reason for this i done this on my champ when i build it because the mojotone layout had it on there. and it is very quite. will this hurt anything?
New builder question about center tap and two 100 ohm res.
Re: New builder question about center tap and two 100 ohm res.
never mind. I found it. i was looking at it wrong.
