Peavey reverb pan
Randy Magee
Peavey reverb pan
Post by Randy Magee »
Does anyone know which reverb pan a Peavey Delta Blues might use? Would a 4EB2C1B work?
Randy Magee
selloutrr
Re: Peavey reverb pan
Post by selloutrr »
If you have the serial number for the amp it would go in. You can call peavey parts and order a direct replacement.
My Daughter Build Stone Henge
ampdoc1
Post by ampdoc1 »
I could be wrong, but I think Peavey used the same pan on most of their products. I still have in stock a Peavey pan I purchased 20+ years ago. It's a 4EB2C1B. If you're replacing one, and it's a full sized pan, I'm pretty sure that's the model.
a'doc1
Randy Magee
Thanks... I was reasonably sure that was the pan I needed for a Delta Blues...
Randy Magee
