Hi Folks!
I have a Supro 1650 TRA on the bench and the reverb tank is done
It is a short tank made by Gibbs and has no markings on it that I can see
Anyone have insight into the appropriate replacement?
Thanks,
Markus V
Reverb replacement Supro 1650 TRA
Markusv
.........Now where did I put it?
Re: Reverb replacement Supro 1650 TRA
You may have to do some measuring of resistance or impedance to figure out a replacement unit.
http://www.amplifiedparts.com/tech_corn ... d_compared
Under the foam in the inside of the tank should be a sticker with information for Gibb/Hammond.
Type 1 and 9 are the short tanks.
http://www.accutronicsreverb.com/
Accutronics equivalent is most probably a Type 4A pan
Pete I was thinking that at first but is the type 4 going to be a short pan as the OP stated his is a short pan?tubeswell wrote:Accutronics equivalent is most probably a Type 4A pan
Types 1 and 8 are the short tanks.M Fowler wrote:Pete I was thinking that at first but is the type 4 going to be a short pan as the OP stated his is a short pan?tubeswell wrote:Accutronics equivalent is most probably a Type 4A pan
Type 1 has 2 springs and type 8 has 3 springs.
rd
Markusv
Thanks folks!!
Yes mine is short pan 2 spring
So I will investigate
Thanks Again!!
Markus V
Thanks Again!!
Markus V
In a general sense any tank with proper input and output impedance can be used as replacement if the original tank can't be repaired.Markusv wrote:Thanks folks!!
Thanks Again!!
Markus V
rd
Markusv
Tue RD
I want the amp to remain fairly close to spec though- the owner insists.
Personally I would have gone with a long tank
