Okay, so I need to be looking for a bum ground then? That helps narrow it down, thanks!
No kidding about this being addictive. This basically turned into my second job.
I'm not an expert in electronics in any sense, I'm a musician that wants to be able to build my own tone out of what I have for not so much money. I'm sure I made some pretty silly mistakes this time around so here are a couple more question that might sound pretty stupid to some of you
1.) The twin red and orange wires that come from the power transformer that go to the rectifier and the 4 & 5 pins of the power tube; does it matter which wire gets hooked up to which pin? In my mind, logically, if it mattered they wouldn't have made them the same color. But that's just me...
2.) I used shielded 20 gauge stranded wire to connect a couple spots where the guy that successfully built the same kit as mine a couple posts above used unshielded buss wire (I think, maybe it's just the leftover bits of a lead from a cap or resistor?). Would that cause problems?
Again, thanks a ton guys, I really appreciate the input!!!!
