7V on heaters of a EF86
mat
Post by mat »
Is it too much ? Does it wear the tube down quicker than 6.3V ?
mat
ChrisM
Re: 7V on heaters of a EF86
Post by ChrisM »
mat wrote:Is it too much ?
Yes
mat wrote:Does it wear the tube down quicker than 6.3V ?
Yes
mat
Post by mat »
Ok, thanks for a quick answer :D I'll insert a 4,7 ohms 1/2 watt resistor in series with one of the filament pins right at the socket.
Yes
Yes
mat
mat wrote:Ok, thanks for a quick answer :D I'll insert a 4,7 ohms 1/2 watt resistor in series with one of the filament pins right at the socket.
I think that is the wrong strategy. If you have 7.0 on one tube, you should have it on all the tubes. Figure the current load (amps) for all the tubes and select a resistor that will do the job for all of them. Place the resistor between the transformer and the first tube.
If you don't know how to figure, post the tube lineup. Someone will help.
mat
Post by mat »
It's the only tube. I built a pedal with one ef86 in it.
mat
Firestorm
Post by Firestorm »
Back-to-back diodes eat up the extra volts pretty easily. You lose the diode drop. Just have to be rated for the power (which sounds small in your situation.)
mat
Post by mat »
Thanks for the tip. I'll try first with the 3W 4R7 I have.
Few pics of the (second) build http://www.flickr.com/photos/fuzzface19 ... 114234737/
Soundsample of the first version: http://soundcloud.com/mattit-1/diy-ef86od-pedal
Firestorm wrote:Back-to-back diodes eat up the extra volts pretty easily. You lose the diode drop. Just have to be rated for the power (which sounds small in your situation.)
mat
Sounds good Mat.
vibratoking
Post by vibratoking »
Some feel that a resistor in both sides of the heater circuit keep it more balanced in terms of noise. YMMV
mat
Post by mat »
Structo wrote:Sounds good Mat.
Thanks Tom 8)
mat
mat
Post by mat »
vibratoking wrote:Some feel that a resistor in both sides of the heater circuit keep it more balanced in terms of noise. YMMV
Ok, I'll try resistor on both sides if the noise is problem.
mat
mat
Post by mat »
2 x 10R in parallel on the other heater wire and got 6.008V on the heater. No noise problem 8)
Might change the resistors to single 4R7 when I actually have one :roll:
Thanks for the tips !
mat
