Guitar amp from a magnavox turntable
I came across an old phonograph player today while cleaning out my mom's house. A Magnavox Stereo 1964566. It has 1 12AX7 and 2 50EH5. thinking about turning it into a guitar amp. Thoughts??
- chocopower
Re: Guitar amp from a magnavox turntable
Sure you can, but you are gonna need another gain stage to raise uo the signal.
I was not familiar with that power tube so I looked it up.
50v heater voltage. Does this amp have a power transformer?
The 50EH5 is only a 5 watt power tube, miniature 7 pin.
Do you have a model number of the phonograph?
http://en.wikipedia.org/wiki/All_American_Five
Run away! The radios got away with it cause they had Bakelite or wood cases and knobs and no one was attached to the chassis via a set of guitar strings and a cord!!!
I saw a guitar conversion someone made once, sounded nice, but I ran away.
Tom,
The model number on the phonograph is 1964566. The amp does not have a power transformer.
David
David
Yeah that is what I suspected.
I remember an old radio my late grandmother had in her basement she would use when she did the laundry.
If it was plugged in the wrong way you would get a hell of a shock when you touched it.
If you decide to do something with it you will need to use a isolation transformer and a three prong cord.
An isolation transformer is one with a 1:1 ration so the voltage is the same but it protects the user from a hot chassis.
