Transformer for Re-amping device
stompjunkie
I've been wanting to try a re-amping device for a while now, and I came across a schematic for one recently. The idea seems interesting, and I should be able to build one relatively cheap. The only thing that has me confused is the transformer.... the tansformer is listed as " a 500 ohm / 30 kilohm audio transformer, such as a UTC 0-10" .... I've done some searching and I've come up with nothing. I've never seen a transformer listed with just impedance before (although I can see why that would be the most important factor in a piece like this...) Can anyone tell me what to look for, or where I can get a nice trannie for this? FWIW.. I'm allready on 10 piece pricing with MM..... Many thanks for all of your help!
- skyboltone
Re: Transformer for Re-amping device
That's an interstage transformer with a 60/1 ratio. Give these guys a call and see if they can help you:
http://www.fairradio.com/
Good luck
Dan
Good luck
Dan
oldhousescott
You might try the Edcor line of matching transformers. Looks like this one might work.
"We put a little quality in everything we build..."
http://www.jensen-transformers.com/apps_sc.html#musical
You might want to look here. They make trannys for a bunch of studio gear.
LeeMo
EDIT: more specifcally
http://www.jensen-transformers.com/as/as092.pdf
LeeMo
stompjunkie
my many many thanks....I'll let you guys know what I go with, and how it all truns out!!!
