5e9a trem uses 2 triode sections and 6g3 only one. 5e9a intensity control will affect the dc bias of the PI as well as the trem strength. Just like the Vibro Champ does, even when switched off. If you removed the trem tube from 5e9a, the PI's bias would be affected since the trem tube pulls its 2nd cathode thru the same path.
2-triode types use the cathode of the 2nd one as the trem's "output." More stamina from the lower impedance when tapping there for sending trem voltage to output grid-leaks.
5e9 uses the more rare PI (paraphase ?) instead of the LTPI. Not sure if that's important or related to the way it's trem is implemented thru the PI's cathode path. I guess that trem could be placed on a LTPI. If NFB is in the vicinity things might get difficult. 6g3 and 5e9a have no NFB.
I used the 6G9-B trem on my cathode biased 6v6 outputs homebrew. Also have a Harmony H415 with a small pentode trem tube and similar insertion approach. Outer intensity lug to ground since no negative DC bias circuit to connect to.
http://www.el34world.com/charts/Schemat ... ny_415.pdf
Default is “On” with the Harmony and 6g9b which I reconfigured to “Off.” Either default can be implemented on these non-roachers. However I find the “Off” default approach does not allow for quick trem turn-on. Not a problem for me. GA19RVT uses this “Off” default via switching the ground of the speed pot.
http://www.el34world.com/charts/Schemat ... -19RVT.pdf
“On” default approach usually grounds “off” the oscillation cap-string via its switch.
