For what it's worth; quasi fixed bias
George61
Post by George61 »
I am fairly new to amp building and I have a 36W Ceriatone which is my 'test bed'. I read a post somewhere about limiting the cathode bias voltage using zener diodes so I gave it a try. The post suggested using zeners that are 1 volt greater than the voltage at idle. I have 11.0 across the cathode bias resistor at idle so I used two 6V 5W zeners in series, as per the post.
The mod didn't make a drastic change but it did have some effect. With the amp cranked the amp seems to be slightly less distorted with more of a Marshall dirt sound which, for my tastes, is an improvement.
Re: For what it's worth; quasi fixed bias
It doesn't matter how it sounds, it only matters that it looks awesome. And that looks awesome. ;)
seedlings
Post by seedlings »
Have you measured Vk when you strum a chord? Does the bias voltage still drift significantly? I have a PP 6L6 cathode-bias build that idles at 35V, but goes to 45V once a chord is played.
CHAD
ChrisM
Post by ChrisM »
That sounds cool, I'll have to try.
What are the brown bias resistors? Make?
Lindz
Post by Lindz »
I found that using this mod helps kill the "18 watt buzz" similar to the way Paul Ruby's diode clamp mod does on the EL84 grids - even more effective on a couple problematic builds I had actually
I also came across a similar variation for "quasi-fixed bias" by Phil Zaphod - http://www.ax84.com/drums/bbs/dm.php?thread=254479 for those that want tighten up a cathode biased amp a little bit
