Well, I did it.(after much brain racking, as I am a noob, and the amp has been modded prior to this, and the resistor I was looking for was not a 470k. lol Took a verrrrry long time to say "I know this is where it is supposed to be, but that isn't it, oh hell, just do it..." lol)The 470k input resistor on the gain-channel is not a fundamental part of that channel. To be precisely, the 1M 500pf combination of the clean channel is still active when the gain channel is activated and the additional 470k in parallel will indeed result in a 391k 500pf combination. This may sound dull. One could remove it or replace it with a 5M resistor.
The Lead channel is too dark or muddy, lacks character & harmonics. This is caused by an unusually low input impedence on the Lead channel of about 319K ohms. To fix this simply remove the 470K ohm input grid to ground resistor on the Lead channel (V1b-7).
Now here is where I run into a problem. The lead channel lost all it's luster, has hardly any gain, and pretty much sounds dull x's 1000. The kicker though, is when I use a overdrive pedal, it sounds like it did with a boost prior to this mod. Is this an impedance issue? Any help would be greatly appreciated!!! Thanks in advance
