how do you remove turrets
wsaraceni
Post by wsaraceni »
i have a g10 board with turrets that look like crap. i'd like to remove them and possibly change them or put in eyelets more likely. thoughts?
Jana
Re: how do you remove turrets
Post by Jana »
Use a drill and carefully drill from the backside (the side that is swaged) until the swage part is cut loose from the turret. Then pull the turret out with a pliers. Use a drill that is a little bit bigger than the shank of the turret (like about 1/8 inch). Be careful not to drill into the g10 or you will enlarge the holes.
mhartman
Post by mhartman »
Jana wrote:Use a drill and carefully drill from the backside (the side that is swaged) until the swage part is cut loose from the turret. Then pull the turret out with a pliers. Use a drill that is a little bit bigger than the shank of the turret (like about 1/8 inch). Be careful not to drill into the g10 or you will enlarge the holes.
This is the way I do it too.
wsaraceni
Post by wsaraceni »
thanks. that's what i figured. i'll suck the solder out tomorrow and try that.
