bigger filter caps
HobbswheresCalvin
bigger filter caps
Post by HobbswheresCalvin »
What happens when you use a bigger electrolytic filter cap then is recommended for an amp design. Say using 47uf instead of 40uf?
Re: bigger filter caps
HobbswheresCalvin wrote:What happens when you use a bigger electrolytic filter cap then is recommended for an amp design. Say using 47uf instead of 40uf?
No problem substituting either of those two values 40uf or 47uf.
If you are using a tube rectifier, just don't exceed the rating for the tube.
diagrammatiks
Post by diagrammatiks »
both 40 and 47 are within the 20 percent tolerance for electros so not much difference there.
HobbswheresCalvin
Awesome, thanks guys
