86ing it: Ef'ing up my amp
- Reeltarded
I am making a parts list to rebuild a JTM 45 Tremolo into a straight JMP 50 with a switchable Ef86 stage in the middle of V2 at the entry of the CF.
The Ef gets it's own drive control, and something of a tone shaper, like the 6-pos control in the brown note layout of the foxy 18. On paper, it seems simple enough to get it as a para/ser on a switch so I can
1. Bypass
2. Cascade
3. Direct to the Ef on it's own input.
My question is about the part when I get it all wired up, and find the gain staging totally underthought, underplanned, and completely misengineered. Is ramming 3 12ax7 triodes down this things throat total overkill? Maybe it should come before V2a, and the switching should include a cold bias for V2a when the 86 is inserted in cascade?
Ideas? Thoughts? I've drawn it out 100 times. Time to make it hurt if I drop it on my toe. Ouch!
1. Bypass
2. Cascade
- chief mushroom cloud
Re: 86ing it: Ef'ing up my amp
look at a Selmer Zodiac schematic.......12ax driving a EF86
Don't overthink it. Just drink it.
I think that Dr. Z got the tone control "right" on the Stangray... Instead of the standard-issue 6-position rotary knob, he went the route of a Baxendall-type eq.Reeltarded wrote:I am making a parts list to rebuild a JTM 45 Tremolo into a straight JMP 50 with a switchable Ef86 stage in the middle of V2 at the entry of the CF.
1. Bypass
2. Cascade
Music is an expression of the inexpressable ~ Vernon Reid, Musician.
- Darkbluemurder
The Baxandall type tone controls are used on the Route 66, KT-45 and Delta 88. The Stangray has only one tone control which is similar to that of the Ghia.rsalinger wrote:I think that Dr. Z got the tone control "right" on the Stangray... Instead of the standard-issue 6-position rotary knob, he went the route of a Baxendall-type eq.Reeltarded wrote:I am making a parts list to rebuild a JTM 45 Tremolo into a straight JMP 50 with a switchable Ef86 stage in the middle of V2 at the entry of the CF.
1. Bypass
2. Cascade
I have used this type of 5879 OD with success. Maybe you can find some ideas to consider with this schematic? The left over triode could be used to have a paralleled V1 ........... OR add a 12A_7 triode as a cathode follower to the 5879.Ideas? Thoughts?
The quasi-sorta 5E3 tone stack works after the 5879.
You might find some other ideas to consider here:
http://www.el34world.com/Forum/index.ph ... 6.msg99077
With respect, 10thtx
Is that lead between the 56k/220k on the 5879 plate supposed to be there?
- Reeltarded
I don't want a full TS for it, but something on a single control. I think I just found a use for a second presonance type control that is scaled a bit differently.
This is going to be a headache. I'm gonna need that pesky math, darn. More discovery. Wooooo!
corrected! thanks, 10thtxIs that lead between the 56k/220k on the 5879 plate supposed to be there?
I've used a Big Muff style TS after EF86 and it smokes. Use 1M resistors and pots to keep the output-input impedance bridging optimised.
(Not so) sorry for hijacking(*) this pretty old thread, but:
- could you explain me what you mean exactly by "optimised", please?
I could read that your variation of the Big Muff tone stack was scaled for a tube amp but the (1:1) ratio between the pot and the resistor values does not match that (3:1) of the Big Muff pedal...
Thousand thanks for the suggestion, by the way...
___
(*) I'm not sure what that means but I've read that several times before ...
