AC "convenience" jack...where can I get one
Been thinking of designing-in an AC convenience jack for my next build. I like 'em because I can plug my effects power supply into one if there is only one outlet for me (and I have forgotten an extension cord with multi outputs).
Where can I get one?
Re: AC "convenience" jack...where can I get one
I thought that it would be easy to find one, but I was wrong.
I did manage to find just what you are looking for at McMaster-Carr. It is their part number 8036K5. A receptacle made to mount in a round chassis hole with two flanges for screws.
Sounds great, right? Well, the price is $19.77 each. So much for convenience!
There has to be a source for these things at a reasonable price somewhere.
I'm not a licensed electrician, so it's not obvious to me what could be wrong about using one of these: http://www.grainger.com/Grainger/LEVITO ... Pid=search comes in white, ivory, and brown! It does gobble up quite a bit of real estate.
This one appears to be more compact, but can't be sure: http://www.automationdirect.com/adc/Sho ... vices/5251
How about something like this?
http://parts.digikey.com/1/parts/100137 ... x2-01.html
I googled "chassis mount AC receptacle".
Mouser carries many different styles.
Check here for starters.
http://www.mouser.com/catalog/catalogUSD/644/1244.pdf
Good luck,
Dave O.
Good luck,
Dave O.
I have used example "H" with success in a number of my builds.
http://www.mouser.com/Catalog/catalogusd/644/1245.pdf
Hit the "Next" and "Previous" buttons for other examples that might work for you.
Dave O.
Dave O.
thanks folks, much obliged!
P.
P.
Type I looks like it kills two birds in one hole! It says snap in mount, solder tab! At the bottom, type E is only 70¢!ampgeek wrote:I have used example "H" with success in a number of my builds.
Dave O.
Weber also sells those square auxillary power plugs.
https://taweber.powweb.com/store/cableord.htm
Mojo has square plug also http://www.mojotone.com/amp-parts/Plugs ... le-AC-Plug
Mojo also sells the Amphenol AC receptacle
http://www.mojotone.com/store?search=amphenol
The round Fender style Amphenol outlet must have gone obsolete.M Fowler wrote:Mojo also sells the Amphenol AC receptacle
Mojo's price is steep and "currently unavailable".
I need (at least) one for a Fender rebuild.
[img:600:418]http://www.mojotone.com/Fender-Backpane ... -image.jpg[/img]
rd
Thanks.
I need to replace the outlet on my Sencore PR57 and that looks like it.
rd
Steve, EDIT no longer available from cooper either I will ask the local cooper sales guy tomorrow.rdjones wrote:The round Fender style Amphenol outlet must have gone obsolete.M Fowler wrote:Mojo also sells the Amphenol AC receptacle
rd
http://www.newark.com/cooper-interconne ... dp/39F1230
Bob Simpson
I have some of those NOS.
3 prong.
Marked:
Amphenol
Chicago, U.S.A.
15A 125V
How many would you need?
Bob
3 prong.
Marked:
Amphenol
Chicago, U.S.A.
15A 125V
Bob
Please understand that IMO an answer to this question is of no practical relevance at all. - Max
Bob it looks rdjones is in need of those.
This is what is appears everyone has switched to in the industry and doesn't work well for us amp restorers.
Bob Simpson
yuck.
Maybe I should keep them...
Bob
Bob
