Presence wiring on the main board
angelodp
Post by angelodp »
Is there any advantage to moving the 390R 1uf arrangement to the main board and then routing the grounds to the speaker ground. Does if affect the operation of the Presence circuit in any way or alter the sonic quality for the better.
Ange
ChrisM
Re: Presence wiring on the main board
Post by ChrisM »
The circuit will be the same regardless of where the ground goes.
HAD probably grounded the presence circuit where he did for lowest noise or some other sonic silliness.
You should put your ODS questions in the Dumble section if you can.
angelodp
Ok
Post by angelodp »
Thanks ChrisM
