1 Pole 4 Position Rotary Switch
Looking for a source for 1 Pole 4 Position 6A Rotary Switch for impedence.
I attached the common 1 pole 3 position photo.
The numbers on the two different switches I have are the same?
Colossal
Re: 1 Pole 4 Position Rotary Switch
Post by Colossal »
Here you go Mark:
http://www.mouser.com/ProductDetail/NKK ... BhxgDCQ%3d
Never mind the example picture.
Dave, thanks so ignore the photo and this NKK is heavy duty enclosed type like the one I pictured?
Colossal
Post by Colossal »
M Fowler wrote:Dave, thanks so ignore the photo and this NKK is heavy duty enclosed type like the one I pictured?
Yep, it looks the same as the standard 3pos you posted. Here is the spec sheet:
http://www.nkkswitches.com/pdf/hs_ps_ts.pdf
Check out page 2. You want the HS13 series.
Dave
