Looking for screen for back of head cab.
playonit
Post by playonit »
I just built a couple of head cabs and am striking out finding a source for the wire mesh some use on the back of their head cabs.
Like this..
I brake for Lard......
srubelva59
Re: Looking for screen for back of head cab.
Post by srubelva59 »
I've used these guys before. Great looking powder coat finish.
http://www.reliablehardware.com/customspeakergrill.aspx
Do a search for "expanded metal" or "perforated metal" You can find small pieces on Amazon.
playonit
Post by playonit »
Thanks Guys......
Go to the home improvement store and get expanded metal lath.
It is usually galvanized steel so you have to paint it.
srubelva59 wrote:I've used these guys before. Great looking powder coat finish.
Awesome!
playonit
Post by playonit »
Yeah... I was at the local H/I store and they have these panels that you sheet metal screw to the bottom of a screen door to keep pets and small children from destroying the screen.. Looks like it will work perfect.. it comes anodized gold or black.. if you cut the panel right at the bottom you can use the bottom of the frame to butt up to the amp.. for a custom look...
selloutrr
Post by selloutrr »
Lowes, home depot, Ace, any sheet metal shop.
My Daughter Build Stone Henge
jjman
Post by jjman »
playonit wrote:Yeah... I was at the local H/I store and they have these panels that you sheet metal screw to the bottom of a screen door to keep pets and small children from destroying the screen.. Looks like it will work perfect.. it comes anodized gold or black.. if you cut the panel right at the bottom you can use the bottom of the frame to butt up to the amp.. for a custom look...
That's what I used. Primed 1st then gloss green for the front and gloss black for the back.
