resource for filter cap replacements
muscmp
Post by muscmp »
i'm trying to replace a cap can from a 1965 sears silvertone 1482. the values are 5uf,10uf and 20uf- - 450 volts. i'll be replacing the can with individual caps. i've not had much luck finding these. i have found the 20uf at mouser for $32!!
any recommendations as to where to purchase these 3 caps? also, do i need to strictly stay with the values?
i've attached the schematic for reference.
thanks,
mikeB.
check out my virtual music instrument museum.
www.muscmp.wordpress.com
selloutrr
Re: resource for filter cap replacements
Post by selloutrr »
tubesandmore.com
In place of 5uf
C-ET4D7-450 Capacitor - Axial Lead Electrolytic, 4.7 µF @ 450 VDC
$1.40 each
10uf
C-ET10-450 Capacitor - Axial Lead Electrolytic, 10 µF @ 450 VDC $1.40 each
20uf
C-ET22-450 Capacitor - Axial Lead Electrolytic, 22 µF @ 450 VDC
$2.20
the caps are usually +/- 20% so you have some wiggle room without any change to the tone.
If you want to replace the can with a multisection
C-EC20-10-10-10 Capacitor - Electrolytic, 20/10/10/10 µF @ 450 VDC
$32.95 each
My Daughter Build Stone Henge
Randy Magee
Post by Randy Magee »
If you're going with individual caps, Antique Electronics has what you need... you don't have to have the exact values... http://tubesandmore.com/
Randy Magee
muscmp
Post by muscmp »
hey, thanks for the fast responses!
really appreciate it!!!!
further question: i've heard you should go higher on the voltage. is that really necessary or is that just a precaution? i've heard i should be going up to 600 or so volts.
mikeB.
selloutrr
Post by selloutrr »
It wont hurt anything to increase the voltage to 600VDC but it will double the physical size of the capacitors. 450Volts will be fine.
surfsup
Post by surfsup »
Hmm interesting plate resistor values 330k/220k...could you please post what it sounds like when you are done?
Since your resevoir cap shows 350 on the schemo, i'm thinking 450 is fine. If you pulled the recto tube and went ss for some reason, the pt will put out 330x1.4=460 so if you ever plan to do that it may be something to think about? Someone else should chime in and get a better answer though.
selloutrr
Post by selloutrr »
sprague makes 450, 500, 600 volt capacitors. round the uF to the closest value.
i.e.
5uf = 4.7uf, 8uf, 10uf.
10uf = 8uf, 10uf
20uf = 20uf, 22uf
if you are keeping the voltage rectifier stock it's a waste of money to buy higher voltage capacitors. I would measure and make sure you have room before you consider increasing the voltage and operating the amplifier with a solid state rectifier.
muscmp
Post by muscmp »
selloutrr wrote:sprague makes 450, 500, 600 volt capacitors. round the uF to the closest value.
i.e.
10uf = 8uf, 10uf
20uf = 20uf, 22uf
yes, i''m keeping the rectifier stock.
thanks again for the great responses!!
mikeB.
It's good to go with a higher voltage rating on old amps because the wall voltage was lower a the time they were designed.
Around 110vac
With todays voltages of 120+ vac you end up with a higher B+ throughout the amp.
selloutrr
Post by selloutrr »
It should only raise the voltage 10% 353V + 10% = ~ 385v which is still safe to run 450Vdc capacitors.
New Production Capacitors are better made to run closer to the operating max voltage then they were when the amp was designed.
If you aren't comfortable with the 450Vdc power rating you can pick a higher voltage with out any change to the tone as long as space allows for the physical size of the larger capacitors.
You may also need to spend more on a name brand capacitor to get the same uF.
look into F&T if the higher voltage rating is something you are interested in.
muscmp
Post by muscmp »
i think i'll stick as close to original as possible, but i am curious as to what F&T is.
selloutrr
Post by selloutrr »
F&T is a german company that makes capacitors.
They are physically smaller then most Sprague brand capacitor making them a good choice in tight builds. They fall in the medium to high price point depending on uf and voltage. They are imported by most tube amplifier supply houses in the USA.
http://www.ftcap.de/seiten/en/home/home.php
rdjones
Post by rdjones »
+1 on F&Ts.
No 600V rated ones, though.
For that it's still the HUGE Sprague Atoms.
rd
gingertube
Post by gingertube »
For new builds and replacement of old caps I use and recommend Panasonic ED Series. Electrolytic Caps have come a huge way in the last 15 or 20 years mostly as a result of the low ESR requirements for modern switch mode power supplies.
For multi cap cans, I leave the old cans in place and just cut the leads to it and replace the caps with individual capacitors fitted under the chassis.
I try to keep the same value - particularly if there is a tube rectifier.
Ian
selloutrr
Post by selloutrr »
it's just as easy to cut open the can and replace the old caps with radial new caps if the visual matters.
