I'm having trouble ID'ing these two caps. They're found in a Champ-type single 6V6 amp.
1)
2200M UW
AUW 1.4KV
This cap is connected to ground and between the Plate of a 6V6 and output transformer.
2)
300K
Z5P
3KV
This cap is connected to ground and the plate of a 12AX7.
The circuit calls for 225VAC input into a bridge rectifier. If the above values are too vague, can someone point out suitable replacements for the described application?
much appreciated.
thanks!!
decoding cap values
Re: decoding cap values
http://www.capacitor-supplier.com/learn ... es-26.htmltraynorbassmate wrote:I'm having trouble ID'ing these two caps. They're found in a Champ-type single 6V6 amp.
1)
2200M UW
AUW 1.4KV
2)
300K
Z5P
3KV
much appreciated.
thanks!!
TM
traynorbassmate
Booya, thanks.
Perfect site for explaining oddball ceramic discs!
