VacuumVoodoo wrote:A word of warning regarding Eagle (which I have been using since 2004).
Always check component PCB footprints in Eagle libraries against original datasheets, especially for switches etc, they're not always correct.
I recommend learning to make your own components library early on, you'll need it.
Agreed but it is a mistake not to check all libraries in any program.
I never use the libraries supplied by any program but use them as a foundation and copy the parts in to your own libraries.
My arm can also be twisted if you send me Eagle files since I have a PCB router, I can do double sided or single sided PCB's Usually much cheaper than a board house if you only need a few, you need eyelets for thru holes though, if my time allows.
This was done on my router with my MITS router, We have done surface mount parts as well, I just need .009" between traces with my standard cutter. I even use this machine to cut pearl inlays for guitars
I wouldn't assume Eagle is really missing anything, I used to use Protel and I am not wanting if fact get things done much quicker in Eagle, Eagle has come a LONG way in the past 5 years and the price is tough to beat. Bruce Egnater actually turned me on to Eagle. I used to use Douglas Cad Cam (I turned Soldano on to that and he still uses it) and then Protel. My only warning about Eagle. MAKE sure you always have the schematic and layout open or you will break connectivity. Another thing I love about Eagle, no backwards or forwards anything. Everything is always connected. Delete something on the schematic and it is gone from the board.
