Tweed Overdrive w/2CF
10thTx
Post by 10thTx »
Thought I'd share back some info as a thanks for the info I've gotten on this TAG forum.
There is an editable ExpressSCH schematic and layout here:
http://www.el34world.com/Forum/index.ph ... #msg113204
with respect, 10thtx
Re: Tweed Overdrive w/2CF
I don't know if I will ever get around to building one of your circuits but wanted to thank you for your hard work making these schematics and sharing them with us.
yurka
Post by yurka »
Interesting design.
oldhousescott
Post by oldhousescott »
Know, too, that unless explicitly stated otherwise, these are all built, tested, and tweaked designs. I know 10thTx spends a lot of time getting the right combination of clarity, note bloom, touch sensitivity, harmonics, etc., at least for his own sensibilities, in each of these designs. He is indeed a very generous fellow to share this hard work. I've played a couple of his amps, and they are as beautiful sounding as they are to look at.
"We put a little quality in everything we build..."
