resistor value
resistor value
could some of you kind people take at look at the picture and give me a opinion as to the value of the resistor
diagrammatiks
Re: resistor value
5 megs.
opinion is why in the world.
Re: resistor value
i,d figured 5.1 meg and i can,t see what function it serves
- statorvane
Re: resistor value
Probably a bleeder resistor.
azatplayer
Re: resistor value
green red green? or is the red actually brown?
5 2 100000, = 5.2M or if its brown 5.1M
Very high/slow for a bleeder.
Re: resistor value
Yes, If that value is correct (which it appears to be) you may as well not have a bleeder there (if that's the intended purpose)....I use 220k/3W as bleeders with good results.azatplayer wrote:green red green? or is the red actually brown?
G
- VacuumVoodoo
Re: resistor value
Perhaps a 5.1M resistor fell into 510k component bin by mistake and continued its journey to the board? A 5.1M bleeder makes no sense. Don't look for secret ingredient where there's none.
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
Zagray!-review
Re: resistor value
It's definitely supposed to be 5M1. It goes across the additional larger filter cap that is switched in when the amp is switched from tube rectifier to solid-state. Maybe intended to suppress the switching transient.
diagrammatiks
Re: resistor value
aha.
if it's in parallel with the bleeder already on the always on cap...and that bleeder is like 220k.
that would make senses.
Re: resistor value
Which amp are we looking at here?
Todd
Todd
Re: resistor value
stray cat ToddT Wilcox wrote:Which amp are we looking at here?
Todd
Re: resistor value
http://www.webphix.com/schematic%20heav ... cat_30.pdf
This is the schem....so what is happening exactly.?
Thank You
Thank You
diagrammatiks
Re: resistor value
there's got to be another bleeder missing or else there is no bleeder resistor in tube rec mode.
also..a 36Hy choke...
is that even possible...it would be the size of a house...
Re: resistor value
Don't know about the 5M1, but 80's Marshalls used 40H chokes.
- VacuumVoodoo
Re: resistor value
"Bleeder" resistors, more correctly called "drain", are not really needed in PSU circuit, but nice to have, where the caps are NOT stacked, they will discharge through the rest of the circuit when you turn the amp off. Voltage equalizing resistors are necessary on stacked caps, drainage function is a freebe they provide.
The 5M1 resistor won't do its expected job the way it's drawn on the schematic.
It should be connected in series with the 100uF cap with the lower switch connected in parallel with the resistor. Switch will short it when changing over to SS rectifier. When in tube rectifier mode the 5M1 resistor will effectively isolate the cap from rest of circuit while keeping it charged.
It's analogous function to a switch parallel with a resistor in series with decoupling cap in cathode of a preamp gain stage. It prevents a switching transient.
Still, 5M1 is ridiculous, 510k would be more than sufficient for this job.
Aleksander Niemand
Zagray!-review
Zagray!-review
