I don't know very much about electronics and need some help.  I'm trying to replace a component in a speaker crossover.  It is about 1.5 inches long,  blue in color.   Printed on it is  Mallory 22mf 75 VNP.   It also has 00517-1080187  and 235-8129E.
Can anybody tell me what this is,   where I could get it,  and what to ask for?   I figured that this would be the right place to go for this information - thank you!!!!!
						Need help with a part
				wingobingo
Re: Need help with a part
Ask for a 22 microfarad capacitor.  75 volts, non-polarized.
It's a 22 microfarad, 75 volt, non-polarized electrolytic capacitor. If you have a local electronics parts supply they might have it. Another option would be to parallel two of these which are found at Radio shack.
http://www.radioshack.com/product/index ... capacitors#
				wingobingo
Thanks for your help with this.  I'm fine with a soldering iron so once I find it should be no problem!!
- Super_Reverb
If you are making an npo with value C from two polarized electrolytics, you need to connect two caps with value 2 x C in *series*. Connect the two (-) sides together and connect the (+) leads to your circuit or connect the two (+) sides of the cap together and connect the (-) leads to your circuit and you are in business.ToneMerc wrote:It's a 22 microfarad, 75 volt, non-polarized electrolytic capacitor. If you have a local electronics parts supply they might have it. Another option would be to parallel two of these which are found at Radio shack.
cheers,
rob
				wingobingo
Another question on this.   I can find 22uF,  non polarized,  but not 75v.  The ones I'm finding are 100v.   Can I use these instead of 75v ?
Yes, the only problem with higher voltage ratings is it usually means the cap is a larger physical size.
				wingobingo
Thanks Tom -  I have plenty of room to work with - its for a crossover in a speaker box - I will order the 100v
