Look at what is on my bench right now!
fusionbear
Post by fusionbear »
I am working on restoring this beast:
[IMG:1024:768]http://i169.photobucket.com/albums/u223 ... G_3368.jpg[/img]
[IMG:1024:768]http://i169.photobucket.com/albums/u223 ... G_3369.jpg[/img]
[IMG:1024:768]http://i169.photobucket.com/albums/u223 ... G_3370.jpg[/img]
Its owner is a prominent South Orange Co. Atty. He has a lot of really cool vintage stuff I have helped him restore or at least get back to working condition. :D
Learning to learn...
Gibsonman63
Re: Look at what is on my bench right now!
Post by Gibsonman63 »
Very cool. SVT, I presume.
fusionbear
Gibsonman63 wrote:Very cool. SVT, I presume.
Yes sir, 1970 if I am correct
Wow what a beast!
Interesting tube locks on the power tubes.
I'll bet that thing is loud when working properly. :shock:
Andy Le Blanc
Post by Andy Le Blanc »
I knew guy, said he used haul one of those around thru the Boston area
T and subway, on his shoulders, can you imagine... put the thing on the
bathroom scale and let us know will ya?...
lazymaryamps
Gibsonman63
I saw BTO about a dozen years ago. Randy Bachman had one of those monsters on each side of the drummer. Sounded really good.
Richie
Post by Richie »
That is an older one 6146 tubes. I've worked on quite afew of these amps.If you replace any of the caps,be sure you ground to the same place the old ones were grounded.
David Root
Post by David Root »
'69, maybe early '70. The Stones toured with these, this was during their Ampeg period, and the plate cap cables would come off all the time, so that's why Ampeg switched to 6550s.
85 or 90 lbs. I can't move mine ('75) any more by myself.
Make sure you change all the filter caps, you may have to approximate some of the values today. And check the heater hum adjustment pot, they are always burned out. Oh, and also check the 8K2 dropping resistor, they burn out too.
In the first photo, what are the tubes hovering overhead?
paulster
Post by paulster »
xtian wrote:In the first photo, what are the tubes hovering overhead?
The SVT has two chassis - one for the power amp which is tubes up and one for the preamp which is tubes down.
It's a bit of a monster!
A small fortune to re-tube that baby! :shock:
fusionbear
Structo wrote:A small fortune to re-tube that baby! :shock:
That is for sure! I got a quote for the customer, darn near a grand just for tubes!
fusionbear
David Root wrote:'69, maybe early '70. The Stones toured with these, this was during their Ampeg period, and the plate cap cables would come off all the time, so that's why Ampeg switched to 6550s.
Duly noted... :shock:
selloutrr
Post by selloutrr »
Make sure to get off the contact as soon as possible the heat from the soldering iron will lift the old traces off the PCB if you aren't careful.
My Daughter Build Stone Henge
Zippy
Post by Zippy »
... all that and the caution regarding PC traces too.
Thanks for reminding me of this amp. I, too, used to work with one - and now I'm recovering from back surgery for a herniated disc. Might be related??? :roll:
