Hi Im just wondering what to do with the center shield on my 9 pin tube sockets. Can I ignore it? Should I use them? Should I pull them out? If I need to use the Center shield, how do I use them......Im guessing they get tied to ground somehow.
Thanks in advance.
Noob question about a pre-amp socket center shield
Whale Meat.....Its whats for dinner.
Re: Noob question about a pre-amp socket center shield
I've only ever seen the centre shield tied to ground once, ever. It was on a croc-skin Selmer T&B mkI head.
You can ignore the centre shield on a 9-pin socket, or tie it to ground for a convenient spot to hook up the shield on shielded wire runs to the grids.
Great thanks so much....this forum has been really helpful and kind with my questions.HTH wrote:I've only ever seen the centre shield tied to ground once, ever. It was on a croc-skin Selmer T&B mkI head.
no problem, we're all here to exchange information and talk amps (hopefully, I've just got here myself)T-diddy wrote:Great thanks so much....this forum has been really helpful and kind with my questions.HTH wrote:I've only ever seen the centre shield tied to ground once, ever. It was on a croc-skin Selmer T&B mkI head.
